RE: Build Thread: New QQ-Yak 54 101", DA-85
Then I installed the servos and marked the center holes for screws. I used an 1/8" bit and did the pilot hole then hit a with thin CA for strength.
The outboard needs a 24" extension and inboard 3". Servos drop in the bays with ease but for the first time I had to shave a little off a bay for the outboard servo to fit. I am sure most of you won't have this problem as this is the first time I actually had to do this but in case you run into this, now you know what to do.
I use dental floss to secure the connectors and tie a couple of knots plus a round of masking tape over the knot.
I also used a 36" rod and passed it through the ribs with a little masking tape attached to the end of it. Grabbed the masking tape and taped the servo lead to it and pulled it through.
