RCU Forums - View Single Post - Cermark SPE 26CC any info
Old 06-27-2008 | 06:32 PM
ed42d-RCU
My Feedback: (13)
Default RE: Cermark SPE 26CC any info
ORIGINAL: gpar
My spe 26 turns a Menz 17x6 at 8700 rpm. I had to change the original carburator for other with a bigger venturi.
The original carburator wt-500b is 9.53 mm venturi. You have to replace it for other ranging from 11.1 mm to 13.4 mm.
gpar, I found BCMA sells a 11.1 venturi Walbro carb and want to swap carbs. Did you enlarge the insulator block opening to match the new larger carb opening?
When I tested the engine with the original carb, I was getting 7500 rpm with a APC 16x8.
