RCU Forums - View Single Post - Equal Elevator trav w/ dual servos
Old 06-28-2008 | 08:41 AM
DavidAgar's Avatar
DavidAgar
My Feedback: (108)
Default RE: Equal Elevator trav w/ dual servos
I am not sure what the MSA 10 is, however I do know that the only real way to make your situation work is to do it with your radio. You need to have one of your elevator halfs be the master and the other be the slave in programming on your transmitter. The slave would be plugged into channel 6 or 7 on your receiver and then programmed to follow your normal elevator channel. Good Luck, Dave
