Engine too big for a Lanier Ultimate P
Hi Endoman
I have ordered a Saito 182 already. I am with you about the looking and also about the power. The Saito 200 weights more than 0.9 lb (400 grs.) than the Saito 182 and this additional weight could offset any advantage in power.
Yes, I am going to use separate servos for the elevators, but at the front of the plane.
This Saito 182 is only 0.35 lbs heavier than the single 180 so I think even if it may have less power, it must be enough for it, apart from the great scale looking and sound.
All your comments has been very helpful.
Thank you very much .
