ORIGINAL: cbrian4
Alright i found out the beeps just got really faint, near impossible to hear. So i would like to try programming the thing using the card that i bought. How do i use it?
**TO BE SAFE...UNPLUG THE MOTOR FROM THE ESC**
plug the end of the esc that plugs into your reciever, to the program card..should be some connectors at the top of the card.(use the one marked ESC) then connect a battery to the esc battery connector..the lights on the card should light up. there are small buttons (probably at the bottom of the card) with arrows pointing up/down , left/right. just use the up/down button to go to the funtion you want to change...the use the left/right button to move the blinking light to the correct setting you want
