RCU Forums - View Single Post - balancing Tower 40 trainer?
Old 06-29-2008 | 01:02 AM
freeair
Default RE: balancing Tower 40 trainer?
with this more powerfull engine fitted you should be right to position the battery pack where you have it now but wrap it in foam and secure it so it doesn,t move, any extra weight needed should be put at the very rear of the fuselage, grab some car wheel stick on lead weights and cut the sections off to the required balance. when your happy with the cog you should fasten the lead with a screw.
