RCU Forums - View Single Post - Charging Tx/Rx frequency
Old 06-29-2008 | 09:44 AM
rctrax
Default RE: Charging Tx/Rx frequency
Charge the nite before each fiying session. Memory is not the problem it once was with modern batterys. Charge both tx and rx. The only time you have to worry about too much charging is when you charge more than 10/c. That's the rate of the chargers that typicaly come with the radio set.
