ORIGINAL: Wayne22
Is there room in the wing for a sullivan saddle tank (11oz) or they also make slim oval tanks of various sizes.....
A draw of that much would certainly require a pump for each, plus if the tanks sit higher than the engines, you will need a shut off valve or clamp when the engines are stopped.....
It's yes and no situation in my opinion, i guess i can cut out some foam between fuselage and IB nacelles on the wing to make a pocket but what type of saddle tanks are you referring to, do you have i picture of it?
