RE: Monsoon Wheels on Avalanche?
The Avalanche wheels will fit the Monsoon, so it should work backwards. The Avalanche tires are taller than the Monsoon tires, so if you install Monsoon wheels/tires onto your Avalanche, expect more low-speed torque at the expense of top speed. Also expect to lose some ground clearance.
They both have 17mm wheels, IIRC, but I think the Monsoon has more offset? I think 1/2" offset wheels should fit just fine, but I don't have either a Monsoon or an Avalanche to prove it, so this is at your own risk.
Edit - are you asking about adding Avalanche tires onto Monsoon wheels? Ew, I haven't got a clue.
