RE: Two 31cc Ryobi's which makes more power
I would like to use the lighter larger port cylinder with the lighter piston, but the skirt on the piston is shorter and the exhaust port is lower on the older cylinder which when at TDC the exhuast opens at the botton of the skirt. Too bad-would give me lighter cylinder, larger ports, lighter piston, qualities for higher revs.
