RCU Forums - View Single Post - Two 31cc Ryobi's which makes more power
Old 06-30-2008 | 02:17 PM
frenchie79
Default RE: Two 31cc Ryobi's which makes more power
I could not believe it but the older model made more power. Using the same carb, muffler, wood 18x8 prop. The newer (at least i think it is) turned in 6930 RPM. The older engine turned 8K even, something must be wrong. The vibration level of the older engine is real high. I don't think it is balanced the same with the heavier piston. How could it turn 1k more RPM??? Any ideas
