RE: CG question
CG is checked with an empty tank, all radio equipment installed/rigged, wheels on, engine installed and covering finished. Pretty much as it will stand at the field before you fuel up. You might wonder what happens with a full tank. The model is a "nose heavy," which is way better than being tail heavy. What is most important to realize is that checking the CG with an empty tank makes sure close to empty or deadstick landing glides are smooth!
