RCU Forums - View Single Post - New Cermark Pitts
Old 07-07-2003 | 11:05 PM
  #33
DKflyer
Default New Cermark Pitts
Actually, the elevator only uses one servo if you build it as per the instructions. The other cut-out is supposed to be for the rudder. I am going to use two elevator servos on mine though, and will put a pull-pull system on the rudder with the servo in the fuselage. And yes, the red scheme is the same as the old cermark pitts.
