RE: Thecheatscalc's 36 tuning and assy
You have a rate gyro (it only has one setting). One end plugs into the rudder port on the rx and the other to the gyro. A heading hold gyro (two switchable settings) has the other plug with a single wire that goes to the ger channel so you can switch from rate mode to heading hold.
