RCU Forums - View Single Post - Wing covering procedure?
Old 07-01-2008 | 11:34 AM
brett65's Avatar
brett65
My Feedback: (18)
Default Wing covering procedure?
I want to cover my wing like the picture shows, do I cover it all in white then put the red on, or is it possible to do it with a little overlap. I don't see how the overlap will work because of the angle and the fact that the open space would be hard to iron the overlap together. I guess it would be possible to lay down a square of red on each end and cut the white to the right angle and lay it on top, what do you think? Also, would it be ok to cover the center line to that it looks like a one piece wing? I'm gonna use auto pin stipe tape for the small white stripe.
