RCU Forums - View Single Post - Draining fuel and running the engine until it quits
Old 07-01-2008 | 12:27 PM
cappaj1's Avatar
cappaj1
Default RE: Draining fuel and running the engine until it quits
Where do you squirt the after run oil? Tower Hobbies says not to put it in the carb as it may cause the O-rings to deteriorate.
They say to pour into the exhaust port - doesn't that require you take the muffler off? Or the glow plug hole.
http://www3.towerhobbies.com/cgi-bin...&I=LXL391&P=ML
