RE: Wing covering procedure?
I tried some pinstripe on the fuse, and it looked good. I used the same brand you had in the video. I have a black&decker heat gun, that makes ungodly amounts of heat. How hot is the heat gun you use for your covering, does it get as hot as the iron. I am afraid of melting it with my gun unless it is supposed to be really hot. This will be my first covering job, and its actually a recovering.
