RCU Forums - View Single Post - Wing covering procedure?
Old 07-01-2008 | 02:37 PM
bkdavy's Avatar
bkdavy
Default RE: Wing covering procedure?
I have used the B&D heat gun, and recently switched to a TH covering heat gun. The covering heat gun is MUCH easier to use. Its not as hot, which makes it easier to shrink the covering where I want it shrunk, and far less likely to burn through.
Brad
