RCU Forums - View Single Post - Himax 6332-230 efficiency improvement
Old 07-01-2008 | 06:06 PM
woodie's Avatar
woodie
Default RE: Himax 6332-230 efficiency improvement
Hey Luke, thanks for information on your experiment. I have not tried the 'low' setting on my Jeti's but may give it a try on the bench. Secondly, the PWM rate at 13 kHz is higher than the 8kHz I am running at. Wonder if that has an impact also. I know when my son Chris tried the higher PMW settings with his Hacker outrunner he got slightly more power but the motor ran much hotter. Can you drop your PWM rate also?
Don
