RCU Forums - View Single Post - 12" prop on a 46AX?
Old 07-02-2008 | 08:31 AM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: 12" prop on a 46AX?
ORIGINAL: CGRetired
GaRCfield: Are you really gaining any benefit from operating that engine at 13,000 RPM besides noise? Even though engines are rated at a certain HP at a certain RPM, (1.6 HP @ 16,000 RPM for instance) that is not a practical RPM range for most engines. Yes, I know, you are not reaching 16K, however, I've found that there are some that just begin to operate well at that RPM, but the general use engines that we use, OS engines for instance, normally like between 11,000 and 12,000 RPM and will run on forever with those numbers.
I prop'ed my smaller planes with that RPM in mind and never had a problem with performance.
Just wondering.
CGr.
Like I said I use the 11x5 prop because it's what came with the Nexstar (which would have come with an OS 46 if I got the RTF) and I thought it has been working well. Also I've read here that people seem to think the OS 46AX and an 11x5 prop is a good match. As you figured, I knew I was well under that 16000rpm mark, so thought I was fine (I get 12,600 actually, just under 13000). I didn't know that 11000 to 12000 was a better mark to shoot for. I'll try a different prop with a tach and see what happens.
