RE: 3w 106 TOC problems
I have a 3w 106 that used to run great when on the ground transition was great and everything. whenever I would roll to knife edge or inverted, it would sag or die. I ended up fixing the problem by leaning the high side ever so slightly. It took about ten takeoffs and landings to get it right, but finally did and now I turn a vess 27 a at about 6700.
