RCU Forums - View Single Post - Pull Pull Help
Old 07-02-2008 | 09:26 AM
jaka
Default RE: Pull Pull Help
Hi!
Crossover is OK!
The arms should in theory be the same length , but in practice a centimeter or two difference doesn't matter.
There is no such thin as ideal servo arm length. But! Remember that there is a rule that says : The servo arm should be as short as possible and the rudder/aileron/ elevator arm as long as possible ! This way you get as little play as possible in the system.
