RE: Diff problem?
Heres how I test for stripped gears that slip. Grab both the front tires with both hands and turn the tires forward and backwards real quick in the same direction. Keep doing it and see if the gears slip and if they make a grinding noise. Make sure the front of the buggy is off the ground. Now do the same thing with the back tires.
