RCU Forums - View Single Post - Diff problem?
Old 07-02-2008 | 03:14 PM
IloveMYxt2's Avatar
IloveMYxt2
Default RE: Diff problem?
ORIGINAL: zonda
IloveMYxt2... I tried this on my Hyper the other day because I wasn't sure if my Diffs were slipping to. should the rear wheels move also when you turn the two front ones in the same direction. I lifted the front end of my buggy up and turned the front wheels forward and the back ones didnt move with it...when i do that on my EB4 S2 they move with the front ones[&:]
Rob
If you have a center diff. then the back wheels wont move if they are on the ground. If you lift the front or back of the buggy up and move the buggy forward the two wheels in the air should move.
If the set screws are loose, use some red loctite. The blue loctite doesnt do its job right.
