RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 07-02-2008 | 06:20 PM
  #6676
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Rick,
Atención, no todos los receptores son creados iguales
As an example, the Futaba and JR receivers have different channel assignment on the receiver.
Futaba channel 1 is aileron, 2 is elevator, 3 is throttle.
JR channel 1 is elevator, 2 is aileron, 3 is throttle.
So, channel 1 and 2 are reversed.
With that in mind, I don't know what the channel assignments are on the AR6100, since I don't have one. If it's different from the Futaba receiver, then labeling the servo connector is a waste of time.
My suggestion would be, to disconnect all the connectors from the futaba receiver. Install the spectrum receiver.
Then, this is the tedious part. Get the working TREX and find what servo goes to what channel on it and copy that over to Trex #2.
Maybe someone else out there knows for sure what the channel assignments are.
¡Buena suerte, mi amigo,
Dave / Choppersrule
ORIGINAL: Barrrick
soliciting a SUGGESTION from somebody with USEABLE BRAINS : that.
[ since I am bereft ]
the new TREX comes with a BUNDLE of connectors that were attached to the Futaba receiver.
Is there some "practical" way to figure out which connector is what ? there are 5 black
and one WHITE that only has 1 wire attached to it. I "guess" that is the GYRO ?
My idea is to get a servo extension, and after BINDING, stick one connector at a time in each slot, then label, until done.
any 'BETTER WAY" ?????
thanks for the LUCKY DOG greeting Mr. DAVE.....I guess that I really am, just like that
A NOTE HERE; FOR MR. VIC MR.SCALER ; tomorrow I will set up the two horizontal stabilizers WITH THE DOWN ANGLE copied from your picture.
HAVING SEEN THE BELL FLY in the picture, do you STILL BELIEVE that they should be attached that way ??????
I mention here that a WEIGHT is attached to the front of the forward cabin, maybe that alone has removed the backwards slide you mentioned ?
