RE: Venom-Racing GPV-1 motorcycle
For the BL motor its 2.3mm and for the brushed motor its 2.0mm. Thats whats most common in those motor shaft sizes. The extra torque of a BL motor requires a slightly larger shaft size to be safe...sen many bend easy at 2mm od. The pitch is .5 mod. On our site we have a broad range of pinion gears you can take a look at.
