RCU Forums - View Single Post - Where should trim be set for throttle and elevator?
Old 07-03-2008 | 12:22 PM
cappaj1's Avatar
cappaj1
Default Where should trim be set for throttle and elevator?
Two questions.
1. How do you correctly set the trim for throttle?
2. If you let go of the right stick it returns to center. Should trims be adjusted here for straight and level flight?
Thank you.
