RCU Forums - View Single Post - F-15 Help Me Decide On Which One Please
Old 07-03-2008 | 01:13 PM
afterburner's Avatar
afterburner
My Feedback: (18)
Default RE: F-15 Help Me Decide On Which One Please
I have a JL F-15 and I would not buy another one. Although Dante from Camlex was great to deal with, I had numerous issues with the quality. The lower part of the struts on both mains bent after smooth landings. Problem was they were not compressing into the upper halves. Instead they were jamming against the the inside so the lowers took the brunt of the landings. The top of the retracts were cutting into the main fuel tanks so much that I had to shim the main gear so the tanks could fit. This prevented the wheels from retracting totally into the fuse so I couldn't put on the gear doors( I just recently corrected that issue by chopping away at the top of the fuse in the main hatch area so the tanks had more room and I removed the shims so now the wheels retract and I could put in gear doors). I had the main header tank split at the seam causing a major fuel leak and had to take apart the fuse to get to it and repair it(I'm running the fueler pump with a 6 cell pack). The paint quality is ok but they missed certain parts altogether. If I had to do it again, I would look at Skymaster or Yellow.
Marty
