RCU Forums - View Single Post - Where should trim be set for throttle and elevator?
Old 07-03-2008 | 02:12 PM
bruce88123
Default RE: Where should trim be set for throttle and elevator?
ORIGINAL: cappaj1
Thanks, Guys,
I plan on getting the Futaba 7C 2.4 GHz radio. I see the trims are digital and require a bump at a time in either direction. Does that radio give you an audible beep for each bump of the trim? Just wondering.
And your "new" trims will be remembered for each plane you program.
