RCU Forums - View Single Post - OpenGL 2.0 Driver ????
Old 07-03-2008 | 09:52 PM
rajul's Avatar
rajul
Moderator
My Feedback: (58)
Default RE: OpenGL 2.0 Driver ????
As a basic practice, it is recommended that you first uninstall the older display drivers before updating to a newer version. To uninstall your current NVIDIA Forceware display driver from your system, please follow these steps:
1) Open the Microsoft Windows Control Panel
2) Double-click the Add/Remove Programs icon
3) Depending on which driver version you are using, your graphics drivers may appear in differently in the list of programs installed.
-For older NVIDIA display drivers, it will be listed as "NVIDIA Windows Display Drivers". Click "Change/Remove" or "Add/Remove " button to remove the drivers from your system.
-For newer display drivers, it will be listed as "NVIDIA Drivers". Click "Change/Remove" or "Add/Remove" button to remove the drivers from your system.
4) Confirm with Windows that you wish to continue with the uninstall
Note: A prompt appears asking whether you want to delete all of the saved nView profiles. If you click Yes, all of the nView software and all of your saved
profiles will be deleted. If you click No, the nView software is removed, but the profile files are saved in the Windows\nView directory on your hard disk. If you take advantage of the nView profiles, you may wish to keep your custom nView profiles.
Once the driver files have uninstalled, Windows will request that you restart your computer to complete the uninstallation.
