RCU Forums - View Single Post - Cheap easy brake solution? What do you think?
Old 05-13-2003 | 11:06 AM
Dekz
Default Cheap easy brake solution? What do you think?
In theory yes this should work. It will definately be "easier" for the srvo to apply pressure if you put it on the inner most setting, whether or not that will result in more braking power I don't know.
