RCU Forums - View Single Post - Battery question
Old 07-05-2008 | 08:47 AM
cappaj1's Avatar
cappaj1
Default RE: Battery question
ORIGINAL: JohnBuckner
Be aware using that pack does not neccessarily get that capacity out of the battery using the wall charger that comes with the radio. To get consistant full capacity charge those batterys are going to need a more capable charger.
You are trying so hard to get everything at once and many bad choices are hard to avoid. What till you actually are flying and many of your choices will change.
John
I have the Multiplex charger on my list http://www3.towerhobbies.com/cgi-bin...&I=LXKSY1&P=ML - that should give them a full charge, correct?
Thanks for the advice!
