RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!
Good Job for you first flight. You will be surprised how slow you can land this aircraft. It has alot of squares and does not have a tendency to tip stall. Slow it down on the down wind and glide her in. The palne is so fast that at half speed it's still faster than most stuff you see flying. Like I said in and earlier post take it high over the field and slow it way down and see it's behaves in slow flight. Pull the noise up and so how it stalls then yo will be ready to grease it in. In a high alpha position.
