RE: Spectrum RX Problems. Please Help!
I'm sorry to hear of your problem. Did you plug your main flight battery directly into the receiver?
Receivers and servos are normally designed to operate on 4.8-6.0 volts. This applies to non-Spektrum receivers as well. The BEC in the speed controller regulates the voltage from the flight battery down to a level that is safe for the receiver.
Good luck with H-L.
- Jeff
