RE: Axe cp gy240 problems
I'm using the GY240 with a castle creations Pixie 7P ESC. The problem i'm getting is the tail just won't stay still - when hovering the tail motor constantly increases/decreases, and the tail must rotate 15 degrees either side of center.
when i test the gyro without the main rotors spun up, the tail motor soons spins up to max RPM when the tail moves, and as soon as i return it to the original heading stops - the problem lays when i'm actually flying, and the tail is constantly pulsing/oscillating either side of "neutral".
i've tried different gain positions on the GY240 - around 50% seems about the most useful position, and the stock (and zero) position on the middle pot on the 3-in-1
i really dont think it's a bad tail motor, it hasn't had more than 10 flights, and the behavior hasn't changed since i first converted - although that's going to be my next step to change,
