RCU Forums - View Single Post - Uni-Flow Tanks
Old 07-06-2008 | 08:07 PM
  #32
vertical grimmace's Avatar
vertical grimmace
Default RE: Uni-Flow Tanks
The one thing about uniflow plumbing is it is no harder than regular plumbing when using 3 lines. So the 3rd may as well be uniflow as it is great to use when draining the tank.
Also, it is imperative that you tank is totally sealed other than the Uniflow line to the muffler. If you have a leak somewhere you will have some engine running problems.
