RE: Help wire my first electric
Thank you for the help first off. Now if I can bother you with a few more questions.....
If proped right, how much flight time should I be getting? Do the battery packs get warm even with the right set up? I mentioned before my charger takes an hour per pack. I understand this to be normal now. However my charger has no way to discharge the packs. It is only a field charger. Do I need something that will cycle them?
Thanks Again, David
