RCU Forums - View Single Post - Testing for amp draw on servos and receivers.
Old 07-06-2008 | 11:56 PM
dixielandsbigal
Default RE: Testing for amp draw on servos and receivers.
Crafty, do you think that perhaps the H9 charger is just overcharging the batteries. W/ the A Cycle you give it the specific mAh and it charges accordingly. Try charging it with the A C, then check the voltage. then discharge. charge with H9 charger and check the voltage. I'm guessing that the H9 is just cutting off at a higher voltage. By the way, most good batteries have no problem with what I called "overcharging". I'd rather be able to fly longer at the field and replace the batteries more often anyway.
