How do 3W props compare?
I've had to drill mine out too,the wood tends to expand a little over time,from the time the prop is originally drilled,shaped,sanded,balanced and finally gets to you the wood contracts and expands with the weather,humidity,temperature,etc. pretty typical to have to ream them out slightly for a proper fit without forcing them on and off.
