RCU Forums - View Single Post - Why is it...........?
Old 07-07-2008 | 10:51 AM
mvallyman's Avatar
mvallyman
My Feedback: (32)
Default RE: Why is it...........?
Did you replace the glow plug in an attempt to fix this problem? OR Has this problem just started since you replaced the plug?
Sounds too lean to me. or a tank problem, tune the motor to peak rpm then richen it a couple hundred rpm then recheck holding the plane with the nose up 45 deg then strait up to simulate a take off.
Tank vent plugged? Muffler pressure nipple plugged? Hole in any of the fuel/Pressure lines?
