RCU Forums - View Single Post - Uni-Flow Tanks
Old 07-07-2008 | 12:13 PM
  #37
Sport_Pilot's Avatar
Sport_Pilot
Default RE: Uni-Flow Tanks
ORIGINAL: MetallicaJunkie
in a UNIFLOW tank there are three lines one to carb, and other to muffler pressure fitting which both have clunks and the third is a vent....
in most of glow planes i run a 3 line tank 2 clunks one to carb, and fueler line wich is plugged after i fuel, and the vent goes to the muffler
could i use a T fitting to fuel uniflow tank from the carb clunk and cap the vent when im done fueling?
Maybe, but it depends on the level of your muffler. It may push raw fuel though it, if you plug or pinch off the muffler line, then that would work. You can also fill it through the muffler line and pinch off the carb line
