RCU Forums - View Single Post - Detailing the Matorro King Tiger
Old 07-07-2008 | 02:19 PM
googlydoogly
Default RE: Detailing the Matorro King Tiger
Thanks for the compliments fellas. And yep, I used an airbrush for the camo work. As for the missing tools on the Matorro, I simply used parts from my old Tamiya King Tiger.
Here's some progress pics. I aibrushed a very thin coat of buff color mixed with dark yellow, to lighten and blend the camo colors to the base color.
Here's some of the tools, painted and weathered. They'll look much better once I spray them with dull coat sealer. The tool clamps are from the Impact set. While the Impact tool clamps are not as detailed as the Wecohe tool clamps, they are much much MUCH easier to work with.
Here are more of the tools and metal tow cable from Schumo. The tow cable holders have working hinges as well. It took a while for me to bend the tow cables into a more realistic shape.
Out of all the tool clamps, this is the only one that doesn't work...because I accidentally glued it.
The C-hooks and C-hook holders.
The hull machine gun.
All I need to do now is to do the wooden jack block (I think that's what it's called), and the fire extinguisher. I also need to add a little bit more chipping and weathering in some areas, and paint over the chipped areas of the zimmerit with more yellow/gray color to hide more of the red oxide primer.
