RE: JR XS3/Stock z270 servo issue
It can be many things.
Check if the Rx is good by connecting another servo to that channel. If it works it's the Rx is fine.
Then, either it's the servo or the servo wire that's broken. Check for a damaged wire. If you see nothign then the sefvo is broken. Send it back.
