UAT plumbing
Hi,
Leave your large "feeder" tank vented outside of the plane, put a piece of tubing on it so you can connect to an external fuel tank clunk line.
Now when filling overflow into a ground unit.
Then after start up you can run on the external ground tank until you are ready to launch, leaving your onboard fuel cell full.
Good Luck,
John Roth
Chicago
