RCU Forums - View Single Post - Question about battery and ESC matching
Old 07-07-2008 | 07:56 PM
bigedmustafa's Avatar
bigedmustafa
Default RE: Question about battery and ESC matching
The battery doesn't push the amps, the electric motor pulls the amps. You want a battery that is rated the same or higher than your motor and ESC or your power system will cut out at full throttle as the battery struggles to provide the juice that the motor and ESC are trying to pull.
