RCU Forums - View Single Post - CX2 servo linkage
Old 07-07-2008 | 08:01 PM
snobelt
Default RE: CX2 servo linkage
Soloboss - you are brilliant! I closely followed your plans to build a lighter flybar. (see photos)
I very carefully balanced the new flybar and it makes a world of difference. Smoother and more responsive. I have not yet moved the servo linkage back to the second hole and I'm not sure I need to. The response is quite impressive and it handles easily - I can finally lock in a dead steady hover. I am still getting a little drift as the airborne stuff heats up but I will mod the case with vent holes as soon as I get the chance. I do already have the motor heat-sinks on and the motors seem to tolorate successive flights quite well. BTW - do I see heat shrink on your flybar? Were you worried about the collars coming loose? Thanks for all your input.
ID:	985881   Click image for larger version
