I am finally planning my truggy project. After a long time of debating I think i found everything i was looking for. I wanted the truggy itself to be top quality without killing my wallet, so me and a buddy found the Ofna Hyper st Pro kit, $450 new, not bad. Of course I will be using to rcm motor mount, if it works with this model. Once it is rereleased i will be using the monster max for this build. I will need a motor for temporary use untill I purchase one of higher quality, so I looked to unitedhobbies. I found the KD36 series to be just what I was looking for. And as long as I am ordering the motor from unitedhobbies I may as well order the other things i need, like a bettery and servo. I have heard good things about the Zippy-H 4000mah 25-35c 5s battery, so why not give it a try. And I found a decent looking servo for dirt cheap, I have no idea what to expect. All links are below:
Truggy: (Ofna Hyper st pro kit)
http://www3.towerhobbies.com/cgi-bin...&I=LXTJH1&P=ML
esc: (Castle Creations Monster max)
http://www3.towerhobbies.com/cgi-bin...&I=LXUWH2&P=ML
Motor: (KD36-74 1900kv)
http://www.hobbycity.com/hobbycity/s...idProduct=6678
Battery: (Zippy-H 4000mah 25-35c 5s)
https://www.hobbycity.com/hobbycity/...5C_Lipoly_Pack
Servo: (SCR 48g / 9.7kg-cm / .12sec Metal Gear Servo)
https://www.hobbycity.com/hobbycity/...idProduct=3880
All comments and suggestions are greatly appreciated. Thank you.
