Adding a ring?
Some pistons have a little extra meat where the ring or rings are and as you move down the skirt it gets thin pretty fast. On the Ryobi I dont know, If there is enough material there it should be a pretty straight forward modification. A fixture or something to hold the piston might need to be made up to keep from crushing or scaring the piston in the chuck of a lathe.
Adam
