RE: Tire Balancer
Tommy - I had one tire that was waaaaaay out of balance. I actually used tiny nuts that I pushed into the putty to get a balanced tire. Use your imagination. I agree with you. Balanced tires makes a bi difference. I noticed it too after I did it. One last thing. Make sre you prep the rim before you put any putty on it. Sand the area first. It will give whatever you use more holding poaer. So far 5 practice tanks, 4 qualifying heats, and 2 mains, and not a single weight thrown. holding up good.
