RCU Forums - View Single Post - Pull-Pull controls - Bellcrank material question
Old 05-14-2003 | 01:51 AM
CafeenMan
Default Pull-Pull controls - Bellcrank material question
All I want to know is if anyone knows if there will be a problem putting the wire directly through the holes drilled in the G10. I don't plan to use steel cable. The stuff I'm planning on using is the same as Spider Wire.
